Canton Racing Oil Pans
![](http://www.tpmarine.com/ProductImages/logos/canton.jpg)
Canton BB Chevy Deep Sump Offshore Marine Pan - 2 piece rear seal - $419.00
Click here to place your order!
![](https://2606042413.monstercommercesites.com/ProductImages/cantonracing/18380P.jpg)
Detailed Description
STYLE: Heavy duty, extra deep Marine oil pan designed for offshore racing.
SIZE: 10" Deep, 14" Long sump holds 10 quarts of oil.
FEATURES: Double trap door baffles, center pickup compartment, removable windage tray, 1/2" N.P.T. fitting on each side of sump.
PART: #18-380 pan for standard Big Block with 2 piece rear seal.
Canton BB Chevy Deep Sump Offshore Marine Pan - Mark V Blocks - $419.00
PART: #18-382 pan for Mark V style Big Blocks with 1 piece rear seal.
Canton BB Chevy Marine Power Pan - Mark V Blocks - $619.00
Click here to place order!
STYLE: Large “T” sump with extra high capacity, and oil recovery pouch for maximum horsepower savings.
SIZE: 8" Deep, 14" Long sump holds 10 quarts of oil.
FEATURES: Six trap doors and two baffles, control the oil flow. Full length oil recovery pouch with built-in scraper. The front portion of the pan is angled for improved drain back and bolt-in windage tray. Notched for sea pump and has three 1/2” N.P.T. fittings and an oil level check.
STARTER: These pans require a rear mounted starter, left side, or an aftermarket starter to clear the oil recovery pouch.
PART: #18-366 pan for Mark V style Big Blocks.
![](http://www.tpmarine.com/ProductImages/cantonracing/18364P.jpg)
Canton BB Chevy Marine Power Pan - 2 piece rear seal - $619.00
PART: #18-364 pan for standard Big Block with 2 piece rear seal.
Canton BB Chevy High Capacity Marine Oil Pan - Mark V Blocks - $399.00
In-Stock & Ready for Delivery!!!
Click here to order or get more info.
STYLE: Stock depth full length sump pan gives greater oil capacity in applications where the pickup is at the flywheel end of the engine.
SIZE: 8" Deep full length sump holds 9 quarts of oil.
FEATURES: Double trap door baffles, bolt-in windage tray and 1/2" N.P.T. fittings on each side of pan for oil drains.
PART: #18-302 pan for Mark V Big Blocks with one piece rear seal.
![](http://www.tpmarine.com/ProductImages/cantonracing/18300P.jpg)
Complete kits now available...includes: Pan, gasket, mounting hardware, pick-up and dipstick...
www.tpmarine.com
![Cool](/forums/images/smilies/cool.gif)
www.tpmarine.com
IN-STOCK READY FOR DELIVERY!!!
