Speed Master PROP LOCK kits in stock
Offshoreonly Advertiser
PROP LOCKS FOR SPEED MASTERS.....
need i say more?
i have the kits in stock and ready to ship
give me a call, i can ship same day
661-295-7000
let me know you saw it here
need i say more?
661-295-7000
I will work on the SSM VI or any drive with the same size prop shaft. The kit was designed to target the SSM VI drive. I did try it on a SSM V that we have in back and it did fit that as well (most likely will fit all the Speed Master Drives)
Originally Posted by 42MTI
Thanks for the quick response, Is this designed for the #6 or is it the McGuard lock for the Blackhawk?
I will double check let you know
Originally Posted by NJgr8ful
#3s??? ... not 3A's
Is that the McGaurd lock for a Bravo3 and then you had a thick washer machined to match the taper of the brass nut? Or did you cut the taper off the nut and supply a thick flat washer.
If so, how thick is the washer part. From your picture it looks to be ~1/2".
teaguecustommarine
New Products and Member Discounts
9
10-02-2006 05:51 PM
