AFR Heads - Build your set!
Triad Performance Marine has made it very easy to build your custom set of AFR heads. Just decide what size heads you need, click on the link and select the valves, anodizing, & cam set-up options.
AFR BBC 305cc As Cast w/o Parts, CNC bowl blends - 119cc
AFR BBC 305cc As Cast w/o Parts, CNC Chambers & CNC bowl blends - 121cc
AFR BBC 305cc As Cast w/Parts, CNC bowl blends - 119cc
AFR BBC 305cc As Cast w/Parts, CNC Chambers & CNC bowl blends - 121cc
AFR 305cc As Cast Magnum BBC Head
AFR's Torque Monster
![](http://www.tpmarine.com/Images/manufacturerlogs/afrogo2sm.gif)
AFR 315cc Fully CNC Ported Magnum BBC Head
AFR BBC 315cc Ported w/o Parts - 121cc
AFR BBC 315cc Ported w/Parts - 121cc
AFR 325cc As Cast Magnum BBC Head
AFR's Best of Both Solution
AFR BBC 325cc As Cast w/o Parts, CNC bowl blends - 119cc
AFR BBC 325cc As Cast w/o Parts, CNC Chambers & CNC bowl blends - 121cc
AFR BBC 325cc As Cast w/Parts, CNC bowl blends - 119
AFR BBC 325cc As Cast w/Parts, CNC Chambers & CNC bowl blends - 121cc
AFR 345cc As Cast Magnum BBC Head
AFR's Magnum Series
AFR's Magnum Series
If “Dirty Harry” drove a racecar, it would certainly be fitted with a pair of 345 “Magnum” cylinder heads.
![EEK!](/forums/images/smilies/eek.gif)
AFR BBC 345cc As Cast w/o Parts, CNC bowl blends - 119cc
AFR BBC 345cc As Cast w/o Parts, CNC Chambers & CNC bowl blends - 121cc
AFR BBC 345cc As Cast w/Parts, CNC bowl blends - 119cc
AFR BBC 345cc As Cast w/Parts, CNC chambers & CNC bowl blend - 121cc
Just in case some of you are planning a winter build, AFR has about a 4 to 6 week lead time on all orders.
I do have 305's & 345's in-stock and 315's on order, but you may want to start thinking about getting those orders placed...
![Evil](/forums/images/smilies/evilB.gif)
