Drive Shower
Pick-Ups Ports:
Has specially designed and tested pick-up ports that deflects more water up the tubes than any other shower on the market (45deg deflection port). The pick up ports are also adjustable up to 1 1/2 inch thru the cavitation plate, thanks to the delrin plastic collar clamps.
Pick-Up tips are tempered for a more durable tip.
Dump Ports:
20 dump ports that sprays the water across the drive in a fan pattern on the sides and the top. More water in direct contact with more of the drives hot surface. Plus 1 anti clog port at the top to prevent the fan spray ports from clogging up with debris.
Adjustable Brackets:
Our showers come with two brackets for two mounting points reducing shower vibration up to 65% over one mounting point. The brackets also allows you to remove the shower without breaking the top cap oil seal again.
Performance:
Our Shower/Cooler has 3 times the water flow than the very popular shower cap design and also provides 15-40 deg lower drive oil temperature. Our showers delivers 25% more water to the drive than the competitors 90° Halo design also providing 20% more cooling. With Just Wicked Marine’s Drive Shower design you get more water flow and lower drive oil Temperature. GUARANTEED
Application:
Our showers will fit Alpha One, Alpha One Gen Two, Bravo One, Bravo Two, Bravo Three and the new XR's with the finned topcap, and ITS.
Also: Bravos with Mayfair and Marine Machine steering.
Colors:
Comes satin finish.
Additional $15.00
Polished or Red, Blue, Purple, Teal. Looks just like all the other marine powder coated colors on the market today (looks anodized). Or powder coated black to match the drive.
Each kit contains:
1 Drive Shower, 2 specially designed stainless brackets, 2- 3/8 bolts, 2 -3/8 washers, 2- stainless spacers, 2 delrin plastic collar clamps, 2 allen wrenches, 2 drill bits and a full color illustrated installation instructions. We'll even add a new 18V cordless drill for an additional $40.00. No other Drive Shower Manufacture supplies you with the tools you need.
Stainless Steel Type:
Our showers are made using seamless T316L 1/2"x .049"
stainless steel tubing for strength and a lifetime of rust free reliability.
Retail $ 117.95
OSO Price $ 100.95
Dump Ports:
Performance:
Application:
Colors:
Comes satin finish.
Additional $15.00
Each kit contains:
Retail $ 117.95
OSO Price $ 100.95
DiamondPerformance
New Products and Member Discounts
3
05-31-2007 08:36 PM
