I'm BACK AND CLEANING HOUSE
#131
I need to convert my bravo water pickup to a through hull style for increased flow.
What do you have or a through transom pickup that would work for this?
#132
Offshoreonly Advertiser
We have many many options for you. First off, are you going to plug off your Transom Water Inlet? If so you will need a S.S. Block Off Plate. If you are blocking this off, I strongly recommend you install one of our side S.S. Side Drive Showers to keep water flowing through your drive which will squirt out on the side of your upper, cooling her off.
Now to the money maker; the Pick Up. Are you going to installing this into a Cat or V? I recommend our S.S. Adjustable Pick Up (S.S., Strongest, Most adjustment, and best $$), or any style of preference. When using a External Pick Pp I strongly recommend you use a Sea Strainer! Give me a call and we can go over your application and get you set up correctly for the least $$... -Eric
S.S. Block off plate-
TCM-2563 ($17.47) oso price..
S.S. Side Shower-
TCM-2005 ($98.28) oso price..
http://teaguecustommarine.com//store...roducts_id=974
S.S. Pick Ups-
TCM- too many options (check out the site and call oso price)..
http://teaguecustommarine.com//store...&cPath=202_699
#133
sea strainers
Hi Eric,
Recently I relocated my Scarab with twin 540's to Havasu and I could not help but notice all the sand that gets moved around in the channel. Needless to say I started wondering if my new motors were protected which got me wondering about sea strainers that my boat has never had. What would you recommend? Also; my fuel gauge is stuck (sometimes breaks loose) do you sell the mechanisms that go into the tanks? While I have you one more thing; I am running your crossovers. Should I be running a thermostat? My water temp is 120 to 130; my oil temp runs between cool and 175 at cruising and WOT.
BTW - thank you for all you guys do for the OSO members.
Chuck
Chuck
#134
Hi Eric,
Chuck
Chuck
Also need oil thermostats ...you need 200+ (215) for oil temps ..... crossovers without thermostats is fine if you can maintain the 200* oil temp @ 130 water temps ....if not you need to run a thermostat ....m
#135
Hi Eric,
Chuck
Chuck
Well its you boaters that keep us in business, so we will do anything to keep you guys happy and keep on boatin!
I always recommend Sea Strainers on every application, no matter what engines you have or what boat you are running. The strainer will pull all the debris out of you system that would potentially hurt your application (you will be amazed what you will find in there). We make many configurations and have fittings that we will form to any application!
Next, like Mike displayed, i recommend the Livorsi Electric Fuel Senders. These guys are cool because for one they dont move (all digital and do not have the float), and 2nd you can adjust the full/empty levels. They hook up the same way as a standard sender, and use the same 5 bolt holes. You might want to pull yours out and make sure that you haven't lost the float, etc.
Oil temperatures are going to be different depending on the engine builder and oil. Our engines run low oil temps along w/ low water temps (should just read on the gauges). We run big oil coolers along w/ no thermostats to keeps our temps down, along w/ running a straight weight viscosity so the oil does not change.
Feel free to give me a call and we can go over strainer configurations, fuel senders, and oil systems! -Eric
#137
Check out or "LSC" Billet Fly Wheels. We use them on ever motor we build and re-work. I attached the link from our site where you can see all the different styles.
http://teaguecustommarine.com//store...yword=fly+whee
We also have every wire harness you could imagine in stock, but the one you are going to need is a Merc# 84-806217A10 (Gen V. Carb. complete engine harness). We sell them for $229.82 (Merc retail $306.42).
Give me a call and I will be happy to provide more info and get you what you need. -Eric
#139
powersteering goodness
We have everything you could imagine for your Power Steering system. From Pumps, reservoirs, overflow tanks, to brackets, braces, extensions, etc… I will throw up our steering add where you can see some of our product. Give me a call for application specifics. -Eric
#140
TEAGUE Used Platinum "XR" Upper Unit
Hey you guys, we were cleaning off our shelves and we put together a used TEAGUE PLATINUM "XR" UPPER UNIT!
Most parts are used, but in good/prestine condition! Mercury 16/19 "XR" gear set, TCM Drive shaft, Large U-Joints, Drive Shower, New seals, New Bearings.
Drive has been assembled by TCM as used, but in excellent condition! -Eric
$2,500.00
$2,500.00
