New Side Mount Billet Throttle/Shifter
Hi, thanks for the posting. The installation of the control itself it pretty simple. Depending on what type access you have in the boat where you want to mount the control will determine the level of difficulty to install it.
If everything is wide open, you can expect a 3-4 hour install. If you need to start removing interior that could change.
You may to change your cables depending on which cables you have. Here's a link to our instruction sheet on the control where it will explain the cables that are required,
http://www.danamarineproducts.com/in...er_1-6_WEB.pdf
I've installed 16-20 units, the first one took me 6 hours. The access was very difficult and we had to remove most of the interior on the drivers side.
I get a very large amount of positive feed back from our customers as well as the OEM's who use them. I've driven several boats equipped with them and there is no comparison when it comes to ease of usage.
The last install I did roughly 2 weeks ago, the guys wife couldn't drive the boat with the Merc plastic control. We did the install, the wife herself called me a few days later and couldn't thank me enough for making her boat fun to drive.
tpmarine.com
New Products and Member Discounts
1
06-28-2007 02:10 PM
tpmarine.com
0
05-06-2007 05:26 PM
Livorsi Marine
0
03-20-2007 10:01 AM
OSO News
Offshoreonly Industry News
0
03-19-2007 10:58 PM
