Livoris Livorsi Livorsi
Old 01-28-2008, 11:15 AM
Offshoreonly Advertiser
teaguecustommarine's Avatar
Default Livoris Livorsi Livorsi
Livorsi Gauges in stock and ready for delivery.
GET UP TO 10% OFF ON ALL LIVORSI PRODUCTS
We are the Largest Stocking Distributor for Livorsi
than anyone, even Livorsi. from 2 1/16" to 4 5/8"
and colors in all black. all white. all platinum or
silver or black carbon fiber with chrome rimes
are in stock and if we don't have it we can order it
and have it on you door step within a week.
Also available Gauges for the Ilmor V-10
Controls for single, dual and triple engine boats
Attached Thumbnails Livoris Livorsi Livorsi-livorsi-1.jpg   Livoris Livorsi Livorsi-livorsi-2.jpg
teaguecustommarine is offline
Old 01-28-2008, 11:19 AM
Default Controls & Throttles
* Bronze and stainless steel
* Adjustable detent and friction
* Available in 9 colors
* Single or Dual In-handle switches
* Adjust resistance without removing unit
* Optional neutral safety switch prevents engine starting while in gear
Old 01-28-2008, 11:28 AM
Default Mechanical Indicators
A mechanical indicator is a unit mounted in the dash used to show the position of drives (units), tabs or flaps or jack plates. A 30 series cable connects the mechanical indicator to the actuator. The actuator is the piece that holds the cable in position on the drive or tab end.
Old 01-28-2008, 12:47 PM
Steve_H
do you have any of the "small" drink holders? cant find them anywhere....
Old 01-29-2008, 10:21 AM
what is the hole size your looking for?
Old 01-29-2008, 01:02 PM
Default Fuel And Water Level Senders
These senders provide an accurate, continuous readout of fuel or water levels even in a moving boat. Consisting of a single in-tank probe and an amplifier, it’s innovative technology renders the traditional float arm assembly obsolete.
* No moving parts, nothing to break or wear out
* Prevents pointer bounce
* Can be cut and calibrated in the field
* Available in 12 or 24 volts
* Detect water in fuel
* Other ohm resistances available
* Requires 12 volts
* Standard SAE 5 bolt pattern
Old 01-29-2008, 04:16 PM
bor
bor's Avatar
looking for a livorsi gps speedokit 3 3/8 whit monster rim and a matching 3 3/8 tacho 8000rpm also whit monster rim
and 2 flat 3 3/8 red bezels
and 5 flat 2 5/8 red bezels
thx bor
bor is offline
Old 01-29-2008, 06:03 PM
no problem i have all of it in stock but i need to know what MPH you need on the speedo kit ?
thx bor
Old 01-30-2008, 07:01 AM
bor
bor's Avatar
little change in plans,just found the mega serie on the catalog,
can you quote me for :
-speedo kit 120mph white face and rim (mega rim)3 3/8
-tacho 8000 rpm white face and rim (mega rim) 3 3/8
red bezels : -2 3 3/8
-5 2 5/8
-1 for antenna
-1 for recal switch
engine is gm ls2 364ci v8
shipped to fl,33311
thx bor
bor is offline
Old 01-30-2008, 10:17 AM
no problem, do you have an email so i can send you the pricing or you can give me a call
-5 2 5/8
-1 for antenna
-1 for recal switch
shipped to fl,33311
thx bor
Quick Reply: Livoris Livorsi Livorsi
