Long blocks & used engines
Offshoreonly Advertiser
We have 2, (yes a matching pair) of 599CU LONG BLOCKS or Complete Engines
Dart 10.2 Billet Cap Block
Crower 4.500 BB 4340 Crank (Internal Balanced)
Carrillo 6.635 Rods
JE 4.603 x 1.270 Pistons (approx 8.87:1 compression)
JE Moly/Hastings Rings
CP 220w ENS Pins
Clevite H Series Bearings
Andrews Hyd Roller .647/.647 lift, .258/.260 duration @.050, 114 lobe
Crane Hyd Roller Lifters
Manley Push Rods
Rollmaster Dual Timing Chain Kit
Melling 10778c Oil Pump w/ ARP Shaft
AFR 357CC CNC Heads
-Tucker Seats
-Manley 2.300 Intake Valves
-Feria 1.900 Exhaust Valves
-ISKY 9925 Hyd Roller Springs
-Manley Cups, Retainers and Keepers
TND Aluminum 1.7 Shaft Rockers
LSC Internal Balanced Flywheel
New TCM Valve Covers
Optional Oil Pan (fit application)
ETC, ETC, ETC
Complete Long Block, ready for a very friendly Nat Asp set up or Light Boost Engine!
Long Block $16,400.00
Complete Engine $23,950.00 (w/out Exhaust)
Complete Engine includes: Intake, 1150 Dom Carb, Complete MSD Ign, Oil Adapter/Cooler/HP6 head/Plumbing, Complete TCM Engine Acc, Engine Water System, etc, etc. Basically complete, run up and ready to install!
Please call for any questions! -Eric
[ATTACH=CONFIG]507168[/ATTACH][ATTACH=CONFIG]507170[/ATTACH][ATTACH=CONFIG]507169[/ATTACH][ATTACH=CONFIG]507171[/ATTACH]
Carrillo 6.635 Rods
CP 220w ENS Pins
Manley Push Rods
AFR 357CC CNC Heads
-Tucker Seats
ETC, ETC, ETC
BBC 460cu SHORT BLOCK
(1) BBC 460cu Short Block, Blower Motor set up
GM 454 mark IV, 4-bolt main, 4.310" bore
Lunati 4.00" x 6.135 crank, int balance, double keyed
Carrillo 6.135 rods w/ WCM7 bolts
JE Pistons, 4.310 bore, 1.640 flat tops. Approx 8.3:1 w/ 118cc head, 8.0:1 w/ 124cc head
Je moly/hastings rings, 52S pins
Clevite H series bearings
Crane billet hyd roller cam, .587/.610 lift, 226/264 duration @ .050, 112 Lobe
Roll Master dual roller chain
ATI internally balanced damper
LSC internal balance billet flywheel
Meling 10778-C oil pump w/ ARP shaft
10qt marine oil pan
Complete Short Block as listed $8997.00
Heads, Exhaust, IGN, Complete Accessories, etc, etc, etc, etc are also available!
Give us a call if you have any questions! -Eric
[ATTACH=CONFIG]507793[/ATTACH][ATTACH=CONFIG]507794[/ATTACH][ATTACH=CONFIG]507795[/ATTACH][ATTACH=CONFIG]507792[/ATTACH]
10qt marine oil pan
