Thermostatically Controlled Combination Cooler
Offshoreonly Advertiser
The ultimate cooler on the market toady! It maintains an even, constant oil temperature thermostatically in one great unit. If you suffer from either high oil temperature or even moisture or condensation in your engine oil this the answer. The thermostat is designed to maintain an oil operating temperature between 190 degrees and 215 degrees. The thermostat causes the oil to bypass the cooler until operating temperature has been reached and then balances oil flow to maintain optimum oil temperature. This alone can save you from years of damage caused by operating your boat with too cold of an oil temperature. Prices starting at $416.00
620-700 - 3" Diameter, 19" Length, 1" NPT Water Connections, 3/4" NPT Oil Connections - For engines up to 700 HP
620-725 - 3" Diameter, 25" Length, 1" NPT Water Connections, 3/4" NPT Oil Connections - For engines up to 1,000 HP
620-750 - 3" Diameter, 22" Length, 1" NPT Water, 3/4" NPT Oil, & 3/8" NPT P/S Connections - For engines up to 700 HP
620-775 - 3" Diameter, 28" Length, 1" NPT Water, 3/4" NPT Oil, & 3/8" NPT P/S Connections - For engines up to 1,000 HP
www.diamondperformanceparts.com
[email protected]
http://www.facebook.com/pages/Diamon...07878772615803
302-521-0123
The Best Parts & Service At The Best Price
[email protected]
302-521-0123
