NorTech 47 Cat "Ballistic"
#52
#56
this must be catman after words on the way home![Lolhit](/forums/images/smilies/more/lolhit.gif)
Attachment 440532
all in fun and games cat just joking![Ernaehrung004](/forums/images/smilies/ernaehrung004.gif)
Attachment 440532
![EEK!](/forums/images/smilies/eek.gif)
#57
![Angry](/forums/images/icons/icon8.gif)
The bottom of this boat has major problems. I was the first (and only) boat that they tried to build using post cured epoxy. The results were disasterous...the boat spent most of its time behind the NorTech shop having holes drilled into the bottom so water could drain, then getting epoxy injected tnto it to "glue" it back together.
#58
#59
Personally , I don't own a boat....but you can't discount the fact that I worked at the Nortech factory while "your boat " was being built, and also when it was back for the many repairs. Does the boat still have the big aluminum plate glued and screwed to the underside rear of the tunnel ?? Gee .... now how would I know about that.![EEK!](/forums/images/smilies/eek.gif)
There's a reason Bill Pyburn didn't keep that boat. You should look into that "Mr Wizzard"
#60
There's a reason Bill Pyburn didn't keep that boat. You should look into that "Mr Wizzard"![Lolhit](/forums/images/smilies/more/lolhit.gif)
