1st time out - My Heat is Sloooooow!!!!
Off the Radar
1 Post
Originally Posted by Nordicflame
Linnie,
that combo will only get you 532 c.i. and make for a one time block.
Stroke it to a 540 and bore notch the block for a proven combination with tons of torque
Of course you could bore it to 4.600 and put a 1/4 stroker crank in there and get your 565 c.i.
That would be a great powerehouse.
Just my thoughts,
Dave
![Drink](/forums/images/smilies/drink.gif)
Just my thoughts,
Dave
Heres the sonic test I did.
It is every bit as thick as the Bow Tie block. If you had a problem you could go to 4.620 with custom pistons. Head gaskets are 4.640 from fel pro that will keep the gasket at least ten in the hole. I think Cometic makes a little larger bore gasket but not sure.
gsmith9898
06-24-2005 04:16 PM
