Go Back  Offshoreonly.com > Owners Forum > Nordic
Installed EMI's, mufflers and new plugs and I'm slower!! >
Old 04-20-2006, 08:14 PM
Kokopelli's Avatar
Default Re: Installed EMI's, mufflers and new plugs and I'm slower!!
Originally Posted by bobl
Possibly a defective or broken spark plug? Pull them all and see if they are indeed firing. You can have a dead or weak cylnder and not really be able to tell on an EFI engine.
Your boat ran 61(GPS) at 4400' elevation before you worked on it? That is pretty impressive! Most Heats that I've seen only run 63-64 at sea level with the stepped hull and 496HO...
I'll take a fresh set with me tomorrow when I test.
Yes 61 (gps) at 4400' with 24 bravo, 62 at 3600' with 24 bravo and 64 at 600' with 26 bravo - I thought that was slow.
Kokopelli is offline
Old 04-20-2006, 08:16 PM
Kokopelli's Avatar
Thanks Dave - ran it with a scan tool today. I may pick you brain though.
Old 04-20-2006, 09:47 PM
Not bad for a Budweiser mechanic! Good luck, that is a fast Heat my old one would only run 62 - 63 on its best day! Non step 502 mpi spinning a 24 B!
Magic Medicine is offline
Old 04-20-2006, 11:44 PM
Steve Zuckerman's Avatar
Kokopelli,
I would check your fuel pressure. Low fuel pressure would show the symptoms your motor is exhibiting. Could be clogged pick up, kinked line(s), stopped up filters, defective pumps, etc.
Regards,
Steve
Steve Zuckerman is offline
Old 04-21-2006, 08:29 AM
Nordicflame's Avatar
Originally Posted by Kokopelli
You may have hit the answer. Since getting the boat last year I've had a problem with it not warming up (posted here about it a few times) and could not figure out why - didn't worry too much as it ran well. Yesterday air temp was about 50 and water temps were very cold - snow run off. Ran it on the scan tool today and it would only warm to 70 and was throwing a cold temp code. Pulled the thermostat housing and the retaining sleeve that directs water was missing (I didn't even know there was supposed to be one) put one in and the boat warmed right up to 162. Also found timing to be a couple degrees off so that was reset as well. I'm going to run it out to the lake again tomrrow after work and test it. This time I'll take my tools and a fresh set of plugs in case.
Nice work...I thought you had the temp deal figured out last year. Obviously a vital piece of info around our parts
Probably worked fine for someone that lives in a warmer environment but not here at this time of year.
I found the same thing on the R-Tech deal I just finished up but was able to change the enrichment temp on that one. Another month and we won't have any problems.
The ice is off Pineview so I at least hope to run up and down the lake once. Leaving for the poker run Thursady afternoon
Dave
Nordicflame is offline
Old 04-21-2006, 08:24 PM
Kokopelli's Avatar
Thanks all for your sugestions and help. I'm running right again. Went back out to the lake and it was running rough but at least warming up. Pulled all the NGK BR6FS plugs I had switched to and replaced with ac delco R43TS ( what was in it before) and the boat ran flawlessly. RPM back to 4900 but only running 59mph, but it was 20 degrees warmer and I had full tanks. Figured I better fill up before it hits $4 a gallon - Can't wait to see what it will cost on the water this summer - any guesses?
Old 04-22-2006, 10:28 AM
Congrats. MR43T are great plugs!
Old 04-22-2006, 02:26 PM
Kokopelli's Avatar
Seem to be. I went with the extended tip version. I was told that the NGK's are a slightly cooler plug and more prone to fouling, so with all the fuel I was dumping in while in enrich mode I guess they just fouled. Good lessons learned for minimum dollars.
Old 04-22-2006, 05:40 PM
Great have fun on the lake!
Kokopelli
22
04-21-2006 08:27 PM
powerguy
8
07-17-2004 08:01 AM
Out There
06-15-2004 01:03 PM
dyno
04-05-2003 11:27 AM
HPJunkie
6
10-23-2002 09:33 PM
Quick Reply: Installed EMI's, mufflers and new plugs and I'm slower!!
