the initial #s are in
#42
It's supposed to handle 800 but the most I've tried is 600. I'm affraid it would be pretty hard on the drive since you have to open the throttle all the way and load it down to whatever RPM you want to start the test. That's a lot more load than it would ever see in the boat.
#43
Didn't hurt anything. Fortunately caught it in time. We're going to beef up a few things and back off on the boost.
Thanks for letting me borrow your prop. I may need to try it again when I'm back together.
Regards,
Steve
#44
If that was me or Butch we probably would have just gave it more gas!! I'm going round with ATI trying to get my ProCharger back before Easter. Those guys suck customer service wise! Whoever is running we'll ride together, Peace out.
#46
Hi Bob,
I always try to keep an eye on things, particularly a new motor. I checked the motor Saturday afternoon, and there was some oil blowing out of the dipstick. Pulled the dipstick, and there was some water in it. I just idled it back in. The motor is fine. Gaskets are OK. I think I lifted the heads from too much cylinder pressure (higher compression and boost). Eric's doing some upgrades and we're backing down on the boost.
And Eric's been on my ass about the nitro methane in the fuel too .............I was having a drag racing deja vu!
Regards,
Steve
Regards,
Steve
#48
Steve,
I talked with EB a few days ago and he told me what was going on. I told him that it sounded like to much water pressure to me. Now, I didn't see it, so its just an educated guess based on what he told me about it. If it only pushed out the gasket around the water passage and not the fire ring, then it's not to much cylinder or boost pressure. If you don't have a water pressure gauge, get one temporarily to test. If you have one, watch it closely. I've seen it more times than I care to remember, especially with Fel-Pro head gaskets. Give me a shout if I can help you guys in any way. See ya, Eddie.
#49
Steve,
Thanks for consulting with Eric on this. He told me you called and I appreciate that. I do have water pressure and more gauges than I can easily monitor. When I had it out last, the pressure seemed normal (25/30ish) PSI WOT. The only way it could have gone up is a fresh housing and impeller and 500 more RPM. We haven't change anything else. We are feeding the intercooler off the Merc single stage pump, which lowers the water pressure about 10 PSI, to the above #s. I do not have a WP gauge on it (the intercooler), but the outlet is on the drivers side, and it's spraying like a garden hose, which is normal.
There is one water pressure possiblilty I hadn't considered. Since the boat is easily 7/8 MPH faster than before, it is ramming more water into the Imco LWP drive. I will keep an eye on it. What kind of pressure do you recommend on applications like mine?
Best Regards,
Steve
#50
FYI. I always run water and fuel pressure gauges and watch them closely while running. I consider these the most important to monitor in a SC application. You can recognize a lot of problems before any damage is done. I can't count the number of times I've had issues that showed up as low water or fuel pressure that could have been catastrophic. The pressure definitely continues to rise as speed increases. Mine runs fairly low until I get up to around 70. Then it gets up to around 20. Water pressure very well may be your culprit.
Bob
Bob
