The motor is out.
#41
Thats not crazy thats a great idea.
#42
#47
John,
Brutal engine!
A nuts and bolts question. What max oil temperature do you see during extended WOT runs and is that oil temperature recorded before or after the oil cooler shown in your picture?
Bill
Brutal engine!
Bill
#49
#50
190* is pretty common for oil re-entering the motor (post cooled) at the pad and is what Merc thermostats the motors to do. This is where most Merc HP motor temps are probed. When the oil at that location is 190* your most likely around 230* in the pan which is perfect.
Your occasional hard runs (which sounds like your good at ) and 210* post cooled temps are probably netting you about 250* in the pan which with good oil isn't going to hurt you for short durations.
To monitor oil temps the best would be two gauges; One on re-entry and one in the pan. This would tell you how much heat your cooler is pulling out of the oil and give you a good indication of whats going on inside.
Beautiful motor!
I'm sure you've noticed how hard that 1/2 stroke hits at 4000 rpm
Dave
Beautiful motor!
Dave
