Nordic Rage, Born Again!
#41
Thanks guys. I will see what props I can round up. The ones I know of that might work are all Bravo 1's; labbed 30, stock 28, and a labbed 28.
When I borrowed the -2; I pulled the spacer, studs, and the splined collar that mates the vertical shaft. When I run the drive without the 1" spacer should I use the stock collar out of my current drive setup? I haven't split my drive yet to see if the collars are different.
Thanks,
Jon
Thanks,
Jon
#42
Thanks,
Jon
Thanks,
Jon
Seems like we used the stock coupler on Mayor Mccheese's -2" Imco lower. Measure the vertical height of the driveshaft above the mating surface on both lowers. If they are the same (I think they are) the stock coupler will be fine.
Good luck with the testing.
BTW, have you measured your current X dimension or prop depth?
Best Regards,
Steve
#43
Steve,
You are correct! It appears the Imco lowers are set up with different vertical shaft lengths so they match the stock mercury shaft length. The spacer kits come with the extended couplers to account for the spacer thickness. I mounted the -2 with the spacer tonight and used the longer coupler. With out the spacer the stock coupler will measure correct.
Stock X is 5.5, first run will be at 4.5.
Thanks,
Jon
Thanks,
Jon
#44
Steve,
Thanks,
Jon
Thanks,
Jon
I think you will be pleased with this test. Theoretically, the shorter, lighter Rage should need need less propshaft depth than our longer, heavier Heats. 5.5" is pretty deep. The factory may (?) be doing this XD because there may not be as much vertical space in the Rage engine compartment (as you have run into with your new bigger/taller engine).
I think you'll see a nice improvement in handling too.
Good luck with your testing!
Best Regards,
Steve
#45
Thanks,
Jon
Thanks,
Jon
If you wanna try a 28 lab or 32 lab, I'm in SLC & have both. I want to get rid of my 28, too small need a 30. Your welcome to try it. Boat looks great!
#46
We briefly met in the Nordic booth at the SLC boat show earlier this year. Not sure if you remember my face… Thanks for the offer 90mph, it would be great to see ya on the water sometime.
#47
That is very generous. I’ve already got a lab 28 and I think your lab 32 would be too much at this altitude. I would really like to try a Merc lab 30 and a Hering with the Imco lower.
#48
Here is the first of the data... I realize this isn't apples to apples due to the temp difference. This is at my local 5000' elevation lake.
With my stock Merc lower at 5.5 XD and a Merc labbed 28 bravo 1 I can run 83gps @ 5600 all day with gear and two people. Temp was mid 70's, boat was very stable.
Today I ran the Imco -2 w/ 1" spacer for an XD of 4.5. I ran 84 @ 5700, no gear and two people. Cruise was 44 @ 3200, temp was 54, boat started to walk, not bad, but soft walk back and forth. Did I gain 1mph from the xd / nose cone or temp?
I tried a B1 30 and ran 82 @ 5200. This did have a killer cruise, 51 @ 3200rpm.
These are not the results I was hopeing for, but good info. My question now is: Should I bolt the stock lower back on and go for a compairable run (temp/load)? Or, since I have the opprotunity, remove the spacer and see what happens at 3.5 XD? It seems like this would be the wrong direction, but don't want to miss the chance.
#50
Chris
Your slip only went up .5%... and you only gained 100 rpm.
I would try taking the spacer out and going for another test run... then report back.
Chris
p.s. my boat is the fastest, and handles the best at 3.0"- 3.5" of propshaft depth with a good 5 blade prop
Chris
