rage trim tab high speed questions
ok guys i am looking for input from guys who have rages that run 85+ mph... i have one with single external steering and no tabs. and get chine at 80 on up . it is a 502 procharged stock drive set up and im wondering how much guys with fast rages use thier tabs if so what angle/ set up length etc. Are they truely a necessary? and is it unrealistic and unsafe to atement 90-95 mph without them. whats the setup and or cure for me wanting a safer stable boat at these speeds? thanks.
im in search of input on setups on fast rages, drive length , prop etc that could contribute the the cause and cure to this problem of my boat. i always ran a stock merc 30p prop. tell me what you fast rage owners have !! thanks guys!
My rage has the merc racing trim tabs, dual external steering and merc 525 it was tested by power boat magazine in 2009 by Bob Teague running it at 82 MPH and he reported the rage was rock solid even docile. I personally haven't had it running that fast since I boat at a higher elevation but i have never had any chine walk even with the trim tabs all the way up. My boat when tested was running a Bravo 1 26 pitch prop. I know others have faster rages so they could probably help a little more, I don't recall them saying there boats were unsafe at 90mph.
Crazy Energy
1 Post
Suggest you talk to the guys at Hydromotive.
Basically the larger the pitch which causes more stern lift pushing the bow down which initiates the porpoising and chine walk..
By switching down to a smaller pitch prop or one with less lift such as a Hydromotive Clever style as opposed to a Bravo (both are 4 blades), the handling problems go away... but rpm increases and you are at your limiter now. Actually a supercharged engine does better at higher RPM... some would
also suggest upping the limiter... Hydromotive will explain why. ( runs cooler) and your max torque point moved up and you want to maintain a 1000 rpm spread between max torque rpm and max rpm.
Depending on RPM with the smaller wheel you may also have to move to a 1.36 gearing in your out drive. That will spin the smaller prop 400+ more rpm a WOT throttle, thus allowing for the smaller prop. However at some point you over power the hull design ( larger K Tabs can help there.).
So the option are
1) A prop with less lift such as a hydromotive clever.
2) Running the boat at higher RPM
3) Changing the I/O gear from 1.5 to 1.36.
You simply can not keep going to a larger prop and not incurr handling problems such as chine walk and porpoising per my experience w/o growing the hull... the stuff they never tell you when you are buying all that power!
So the option are
Chris
x2
Single engined v-hulls handle better with smaller pitched props...for lots of reasons.
I suggest going to a 1.35 gear aproximately... and going with a smaller pitched props.
Chris
Chris
thank you guys!! this is exactly what i was looking for .. ill save the money that would be wasted on tabs and buy steering. any suggestions on best brand or deal to go with? and i do have a hydo 28 prop with no bell that i have not gotten to demo yet to see if it helps any as well.
