Has anyone had to cut out the navigation light assembly to change a bulb?
Glad it worked out! Jay, you can just reach up there and push them out with your arm. You don't need to really crawl in there, just push gently and use something with a blunt end on it (not something like the pointy end of a screwdriver as I think this would increase your chance of hurting the lens.)
I did mine today, popped right out.
I ordered these in white, I'll let you know how they work. The website said to used colored LED's, I'm going with the white. We'll see.
http://www.superbrightleds.com/morei...d-festoon/237/
Don't forget to lubricate your stern light while you are checking out the bow LED's. They don't make the auto stern light anymore so don't forget to lube often. If not the plastic gear will strip and you will have to replace it with a manual one.
