Just when I needed a camera...I forgot it
Re: Just when I needed a camera...I forgot it
Originally Posted by sommerfliesby
Even without the tour, it might be a good idea. South Haven is always fun.
Originally Posted by 10x
Maybe we should just plan on having a Michigan party.
South Haven would also be my first choice. Second choice would probably be Holland or Grand Rapids.
I'd be up for another "Skater" tour again. Besides, we know 2 people that are currently having cats built there right now. Skater Chris, and Fred Neilsen.
Originally Posted by Bob Zubik
So when am I going to the Michigan Party???
What weekends do you have open. We would hate to interrupt the 2007 BZ World Tour!
I saw you newly painted valve covers and spark arrestors Frank! Looked pretty good. Guess you had to do something with that....uh...well, other stuff that was on there eh?
Hey, I'd be up for a South Haven gig this winter! That was fun last time....Donna did a great job with it all.
Crazydave, your avitar kinda looks like an aircraft carrier---complete with square flight deck elevators!
Yeah, maybe I'll install a couple of catapults to shoot stuff at you when you fly past me,,,,,,,,,They don't call 'em flat decks for nothing.
new guy on the block with a 38' fountain 2007. twin 525 staggared. 1st time with a closed cooling system and i am trying to make sure that i winterize boat correctly. how do i flush out exhaust system and then winterize? i have ordered service manual, but have not received. normally i would pump antifreeze through system. again how do you pump through system. it appears that not only in the lower unit, the water pickup is also on the bottom of the boat???
would appreciate any help for this rookie.
Charter Member #927
Steve, welcome. Maybe you should post this in the tech section. You'll get more response. Depending on the exhaust you have, I think all you have to do is pull the drain plugs to drain out the water.
Drain the headers, drain the oil coolers both P/S and engine oil, drain the sea strainer and pull the hose off the sea pump intake to drain the pump and lines.
