Old school 1990 35' Express project starting soon
#91
Crazy Energy
1 Post
[ATTACH=CONFIG]503939[/ATTACH][ATTACH=CONFIG]503940[/ATTACH][ATTACH=CONFIG]503941[/ATTACH][ATTACH=CONFIG]503942[/ATTACH]
Bob has started laying out the dash for the 22 Auto Meter monster gauges / 2 drive one monster tab indicator / Garmin 740S GPS. Then the wiring process. Tilt steering will be Port side. This OE has 4 aluminum fuel cells so we have 4 fuel gauges and a good range for when we head out to the Bahama's for a cold beer.
#92
Crazy Energy
1 Post
[ATTACH=CONFIG]503944[/ATTACH][ATTACH=CONFIG]503945[/ATTACH]
This is what I'm making the exhaust trim rings out of. I have 3 of these Aluminum 5.75 ID X 7.75 OD X 2" Wide.
I plan on cutting 2 of them in half for the 4 outside transom rings 1" thick.
The other one in 4 pieces 1/2" thick for the inside transom.
Then drill & tap the inside transom side of the outside 1" rings about 3/4" depth for the bolts to screw into but not all the way thru.
This will hide the holes from the outside for a clean look.
The bolts will go thru from the inside bilge rings and screw into the outside ring tapped holes to snug up everything. This should give the 5 1/2" cannons a bolder look.
I'm hoping.
Probably polished and anodize clear but not sure on that..
I'm hoping.
#95
Crazy Energy
1 Post
Finally got my trim rings machined for the 5 1/2" cannons. We beveled the outer and inner of the outside rings, drilled 6 holes on the inside of the rings of those so no bolts will show from the outside of the rings and inserted Heli Coils in the holes so the aluminum won't strip out. Now they are off to be anodized
[ATTACH=CONFIG]505235[/ATTACH][ATTACH=CONFIG]505237[/ATTACH]
[ATTACH=CONFIG]505238[/ATTACH][ATTACH=CONFIG]505239[/ATTACH]
Heli Coil
[ATTACH=CONFIG]505240[/ATTACH]
Heli Coil
#96
Crazy Energy
1 Post
I got my exhaust rings back from the anodize guy today. I had them done in 2 staged black. The drives / tunnel tab / and rings are all black. I'm very happy the way they turned out.
[ATTACH=CONFIG]505935[/ATTACH][ATTACH=CONFIG]505936[/ATTACH][ATTACH=CONFIG]505937[/ATTACH][ATTACH=CONFIG]505938[/ATTACH]
#97
Crazy Energy
1 Post
[ATTACH=CONFIG]506240[/ATTACH][ATTACH=CONFIG]506241[/ATTACH]
I bought some insurance.
2- Hardin marine 2 stage sea water pumps and 2- sand strainers.
#98
