OE 25 rigging
OE 25 rigging
Can anyone post pics of the rigging in the rear where the batteries go in a 25 Express. I bought one that is stripped and would like to rig it the same as factory. Thank you.
Scott, Mine are under the rear seat. Depending on your CG you might want to put them up front? Mine is still in storage, so no pics for awhile. But I remember two knees on top of the tunnel (to the deck) with oil tanks in between. Two big bulkheads going fore/aft from the bottom of the tunnel sides up to the deck and to the transom. It is tight in there.............
Good Luck.............
Thanks jolly! I think these guys removed the oil tanks and had the batteries in the rear transom area above the tunnel. this is a 1999 double step 25 OE. Is there a sweet spot for the CG????
