Livorsi Has An Affordable Solution If You Are Looking To Upgrade To A GPS Speedometer
![](http://i1225.photobucket.com/albums/ee382/internetbrands1/livorsi.png)
With Livorsi's GPS Pulse Antenna,
You'll Never Need To Calibrate Your Speedometer Again
Convert your electronic speedometer into a GPS driven speedometer with this GPS Pulse Antenna. The antenna receives GPS satellite signals and outputs the information to an 8,000 or 16,000 pulse signal to drive your existing electronic speedometer.
This fast update antenna receives ten GPS signals per second, driving your electronic speedometer to display your actual speed (featuring virtually no pointer lag) and it tracks mileage. This universal antenna is truly a stand alone device, as it does not require any connections to the transmission. There is no mechanical to electrical sender device. It has no moving parts: it only needs an open view of the sky. You do not need to route any wires though the firewall - installation is a snap! Regardless of what modifications you have done or will do to your ride (i.e. tire size changes for drag racing or off-roading, gear ratio replacement, etc), never again will you need to calibrate your speedometer. No more measuring miles on the road, driving, pushing buttons OR completing complex math to figure what switches to turn on and off. Simply wire this in, turn it on, and drive!
This antenna is small and stealth enough to mount under the dash or paint it to match your vehicle's color scheme. Accuracy and ease of installation makes this GPS Pulse Antenna an affordable solution if you are looking to upgrade to a GPS speedometer system.
o Works with ANY electronic speedo that requires either
an 8k or 16k pulse per mile square wave signal
o Eliminates cables to transmission and wiring through the firewall - installation is a breeze!
o Does not require membership fee for GPS service
o No calibration needed, ever!
o Ready to use out of the box
o Operating voltage is 10-32V DC
o Pulse output is a square wave
o 10Hz update for real time data (10 samples per second)
o 2 3/4 in. L x 2 3/8 in. W x 7/8 in. H
o 4 foot harness and ring terminals included for connection
