VHF Radio with intercom in helmet HELP
whos' system do you have? did you check your antenna connections?
did your problem just start or is this a new setup? Im thinking your problem is antenna related.
this is a on going problem,antenna was worked on in Key West and it help but didn't fix the problems and we have always had to be close to race control to talk to them and it still come in garbled.
whos system?
If you are transmitting and receiving at close range, it still leads me to believe your ant is bad. maybe a bad ground or something like that.
I would pull the antenna and put a new one in. Im sure there are meters you can buy at radio shack to check your RF gain. If you are racing in Destin, Racing Communications will be there and possibly be able to help you out.
Roger that...I have the same in my boat and racing communications can most likely help you with them. you may want to give them a call. they may be able to help you trouble shoot your problem.
1 800 990 9941
www.racingcommunications.com
1 800 990 9941
