extreme g-127 vid 1st super stock race chatanooga tn
Michigan Mad Man
![](https://www.offshoreonly.com/forums/images/icons/racer_member_star.gif)
Registered User
Yea Kinda like Cambridge, When the roles were reversed. I didnt hear anyone crying then. Smitty
Michigan Mad Man
In Cambridge we had our back up motor in it is down almost 100 HP from our good engine. We got behind the Dukes and that Bad Boy boat on the start because I was lined up with all the other boats when they thru the flag. It took me 3 laps of getting completly hosed down to get by those two boats. I got by on the inside of both of them. Chris said he tried following our line thru the corners and could not keep up with our accelleration. So then I put are #1 engine in that has head snapping accelleration and all of a sudden I get played with the whole race and get passed 50 feet at the finish line. I am going down the staightaway right on my limiter and they got all kinds of throttle to catch me, ride along side, then leave me. Just because I am in the entry level class don't mean I am stupid and know when I am getting played. You put yourself in my shoes You had Louie covered all year then he shows up in Chattonoga runs right along side you the whole race and passes you 50 feet from the end with the same setup he ran all year. You would have kicked the windsheild out of your boat. I am not wining or complaning about losing I don't mind losing when we get beat but when you mess with the rev limiter that's not fair. I feel I wasted the whole last month building 2 motors, buying extra GPS's and software to read them, moving them around in the boat to find the differences, getting 4 props made and testing the boat with accellerometers in the boat to maximize accelleration, then have Sponsors and freinds come all the way to TN for that. I know you did a lot of work and put alot of time into the OPA and I am not bashing all your work But the GPS system works real well I think everybody needs to have 2 on board just in case 1 does not read. Also everyone needs to wire them direct to their ignition so they power up when they start the boat ( no more charging the little battery that goes dead. ) We also need to monitor engine RPM thru out the whole race I am working on a inexspensive way to track RPM's thru the race. I think Frank controlling the GPS's and we come up with a way to track RPM's that will eliminate alot of trouble.
Registered User
We have a Gps in developement that will stop the boat at any speed we wish. It eliminates having to read anything. We simply set it to hit the limiter at 70. The other answer is Ocean Racing. I am definately looking for more Offshore sites.
Racer
Who cares if the REV Limiter was removed? If there GPS Showed they did not break out that’s all that matters and if you thought the limiter was removed you should have said something then and had Smitty run the boat. No point in *****ing now.
Racer
Call or PM Sleepy Pirate, he works with the auto company that developed this or something similar, he had nothing but problems trying to get it to work before Algonac.
Michigan Mad Man
Michigan Mad Man
