Prop Testing on 24 >
Prop Testing on 24
Prop Testing on 24
Old 06-29-2005, 08:58 AM
  #31
Pat McPherson's Avatar
Default Re: Prop Testing on 24
Will a labbed 24 get less cruise than a stock 24B1?
It all depends how the prop was altered...
From my experience, it is better to test with stock props.
Pick what works best stock, then tweak for that last 1-2mph.
"Labbed" props don't always work better. It may take a few tries...
Patrick
Pat McPherson is offline
Old 07-05-2005, 01:25 PM
  #32
JC Performance Engines
Stormrider's Avatar
Tested the 22B1 this weekend.
Not Good.
Got up on plane a bit easier, and was able to take more trim.
But I lost 2 mph at cruise speed, and lost 3mph top end.
And I cant tell if I like the 4 blade better than the 3, maybe since I'm so used to the 3blade Mir +.
Stormrider is offline
Old 07-06-2005, 04:21 PM
  #33
Not Good.
Storm, a 22p Bravo has quite a bit less pitch than a 23p Mirage +. Bravos tend to measure low and Mirage + high.
You are going to loose speed with a 22p at the same rpm.
You need to try a stock 24p Bravo 1. You should gain a little cruising speed but will not likely on top. The Bravo 1 is a better rough water prop in my opinion though.
Patrick
Old 07-06-2005, 07:23 PM
  #34
Stormrider's Avatar
I'm waiting for the demo shop to call me when the 24B1 comes available.
In the meantime, I'm bringing the boat to the southshore for some oceanrunningfun... finally!
UNSANE
Prop Talk
4
01-25-2008 09:37 AM
tssteph
Prop Talk
13
06-06-2005 06:45 PM
502SCS
02-12-2005 09:52 PM
klaw
11-09-2004 12:47 PM
baja27
Powerplay
10
04-16-2004 08:12 AM
Quick Reply: Prop Testing on 24
