Winter Freshen Up...
#31
I had a 1978 28ss like yours. The original power was 280HP/350s hook to TRS drives. The boat ran about 60mph on her best day. We bumped the power to about 320 per side with new cams and intakes and she still only ran a best of 63mph while we owned her. I must say that boat was/is a wave crusher...
Patrick
Patrick
#32
Pat,
Yea, I have about 300 per side. I'll eventually put a nice set of 383's in it but the TRS drives really slow it down because theyre so deep. And 20 grand for Konrads is out of the question. But yes, it goes through 2-3 foot chop like a freight train. Much like the 28 Pantera.
#34
My 24 used to run a 29P Mirage. Not a plus, just a Mirage. Previous owner got 91 on radar with it with 620 HP.
I still have it if you are interested in purchasing it cheap. It is in perfect shape.
Kirk
Kirk
#35
Hey T.
I got my boat running yesterday. Time to mount the drive and fix a bunch of little things. She should be ready for the water first weekend in May.
How's your project going?
Patrick
Patrick
#36
Pat,
One thing I never did try but I do know a fellow that had good luck with.
Have you ever tried spinning the props in rather than out?
Patrick
Patrick
#38
Grab a buddy and a 12 pack. You can have those drives swapped in 30min.
What are you running for props?
The fellow I know ran Mirages.
We found Turbo Vectors were a tick faster than Mirages.
Patrick
Patrick
#39
Hey T.
I have a labbed 26p B1 I just got back from BBlades. The prop has been works a few times so the blades are a little smaller than stock and real thin like a knife.
I bet your beast would spin close to 6K with this prop.
Ready to test yet?
Ready to test yet?
Patrick
Patrick
#40
T-Mone
Sounds good Pat, I will be running the boat this Sat. I need to finish up the fuel lines on Fri. night Put the engine hatch back on and I should be ready to go. I will let you know how I make out. Trevor and Morgan are taking me up to some lake in Pa. Trevors got that pro charged 26 sonic, I guess I will have to see if I can hang..Looking forward to this weekend. Talk to soon Ant..
