Extension Box Opinions
I'm considering adding an extension box. I saw that B-Stubb put one on and seemed to like it. I'd like to get some additional comments on it and whether it's currently worth the trouble. The boat is a notch transom boat, I'll be using it in the Pacific ocean and lets assume current max speed between 65 - 70 mph.
What do you guys think?
I had thought about an ext box on it as well. I think Bruce Seroff??? had one as well. Don't remember the results or if he did multiple changes at the same time. I think the 11* transom angle comes into play. Also, for reference, Cattitude's 28 has an ITS with no notch.
Yah, I'm curious to see if people think it makes a difference and if so whether it's worth it. I'd also like to hear what people think of Stellings vs. Imco.
I had a stellings box on my 1993 race 28 pantera worked good,was tough on drives no rubber coupler,i would prefer using imco box,still uses merc coupler and also uses nice torsional input shaft,a lot easier on drives,you will need atransom wedge made,my motor was mounted foward on driveshaft so i did not use wedge
My Konrad has an 8" box and the boat responded awesome with it. It gets on plane very well and runs excellent with the box.
I also had them make an 11 degree to 13 degree angle adapter plate though!
Interesting, it doesn't look like B-Stubb used a wedge spacer with his new Imco box. Could this have to do with motor placement differences between a notched boat and standard?
MDG, is this what you're talking about when you say the motor is mounted forward on the driveshaft?
Yes...I had one and it didnt work for me. I kept breaking the vertical shaft in my drives, and took me out of many races. I took it off and the boat ran better and no broken drives. If Im not mistaken, i think it has something to do with the angle of the Pantera transom vs. the angle of the box. the money and labor to switch, is not worth the minimal (if any) improvement in performance. The boat already runs and feels like most 30-32s. Spend your money elsewhere.
Transom angle on the 28' is 11 and most boxes are built for a 13 degree transom angle. I have never seen big performance gains with them.
JO
JO
