At Least I Look Fast Now!!
Thanks Jo. Wasn't trying to totally copy your design I think it's different enough that the 36 owner wouldn't be mad. I hope!
Testing a 29P Mirage plus and then the spacer this week.
My bow stop took its toll on the front though so the designer and I need to come up with a solution. The bow stop hits right at the lifting eye and then the boat slides up as you winch it on the trailer. the dragging of the bow stop tore up the vinyl. I'm thinking some creative triming to get down to the gel in that area is the only solution.
It's clear right there anyway, right? So no problem.
To help keep a smooth line when you trim, use 1/4" fine line tape to mark your line... then use it as an edge to press the xacto blade against as you cut.
Great looking job!
Very nice.
