Redoing the interior in my 28
#31
Tomas, everything looks awesome! At least someone's enjoying the weak US dollar!
What's the story with drive oil pump and cooler? I was thinking about something like that recently.
Again, looks great!!
#32
There's also a new fuel pump and all the fuel hoses has been redone (again) and I have also redone some of the wiring with a couple relays etc. Moved the batteries to infront of the cockpit since I removed the lead plates from the bow.
Some of the pics are a bit old so it's not the final results...
#33
![Stick Out Tongue](/forums/images/smilies/tongue.gif)
Thanks!
Heat (and metal) is what kills the Bravo's so the oil cooler together with the filter will definately help it stay alive for a long time. I don't trust the drive showers to keep the oil temp as cool as it should be so this is the best solution. I have an oil temp gauge, from the same series as the rest of the gauges, on its way over the pond right now.
I can definately recommend Mr Gadgets. He's VERY good to do business with!
#34
There was 12 pieces of 30lbs (or so) lead plates bolted to the bow. I will start with the batteries as the only weight in the bow and will most likely put back some lead plates when I have tried it out for a few runs.
#35
Yeah, I had to make an aluminum bracket to bolt the front side of the battery brackets to and bolted the back side to the bulkhead.
#36
#37
I hope it looks familiar since it's coming from you. I kind of look forward to that teaser pic...
![Evil](/forums/images/smilies/evilB.gif)
#39
