Where to find Dash Panel Circuit Breakers? >
Old 05-20-2008, 06:42 PM
Back out of the Game!
mikeb4's Avatar
Default Where to find Dash Panel Circuit Breakers?
I have one dash panel circuit breaker for the horn that is acting up, the switch & horn only work when you are pressing down on the little white breaker button.
Is there a way to clean these out, reset them a couple times to clean the contacts? or where can I find a replacement? checked the common marine supply websites but did not find the breakers?? thanks!
mikeb4 is offline
Old 05-20-2008, 06:53 PM
good question. you might try "digit key" electronics supplier.
maybe it's spelled digi key.
If you can't find a match and it means that much to you, you could bypas it from behind and run a fuse holder behind the pannel. It would still look the same from the top.
tomcei is offline
Old 05-20-2008, 08:49 PM
mikeb4's Avatar
GREAT tip - here the place is ... now I just need to get a part number off of mine to narrow it down ... http://digi-key.dirxion.com/Main.asp
Thanks!
mikeb4 is offline
THEKID29FEVER
Fountain
3
06-09-2008 12:24 PM
Steve_H
Cigarette
4
01-06-2008 10:19 AM
mikesonic
Sonic
0
06-26-2006 08:56 PM
wantsa311
06-27-2005 05:12 AM
p4-33
0
03-27-2004 11:22 AM
Quick Reply: Where to find Dash Panel Circuit Breakers?
