What's the best place to buy a replacement hydraulic trim tab motor?/
Title says it all. Removed the starboard side today. Was making a funny noise and spewing fluid everywhere. Is there anyone who rebuilds them? Just a thought. Thanks.
pump
hi chad try these they stock every part you could ever need you probly wont have to buy the whole pump ,the parts book they have sent me is 2 inches thick, iam hopeing i wont need it too often,(SIERRA)phone 217 324 9461.....or technical support 217 324 9428 .a fim called key parts sent me my book when i orderd oil and filters last week i have the same set up as you have but 2001 locking for some good second hand E top headers for my twin 496 ho pantera put a thread out yesterday but it has been moved to the other sit ???good luck its worth geting book as they do a break down of parts for the pumps regards paul from england
Back out of the Game!
Well figured out part of the problem tonight. Seems the pump is fine...bench tested and works great. Must have had some air in the line combined with a leak either in one of the hoses, or one of the 90 elbow fittings. Trying to get some new fittings but don't think that will be an easy job
Did it. Actually found the pump is fine. The problem was air and water in system. Problem solved. Now I still have the leak to contend with...have a bad elbow on line into pump and another bad elbow on the back from trim tab to stern. Sending off to Pepe tomorrow. Hoping to have back so I can launch her next weekend. Wish I had a local place to buy fittings.
