bigboat28 pics
I bought a set from Trick
years ago,there white with a little flip deal in the middle so you can turn them.
![Lolhit](/forums/images/smilies/more/lolhit.gif)
Going back and looking at your pics, the caps that I have look the same as what you have.
Craney, did your new caps screw right into the exisisting fill, or did you change it? Do you have 2 tanks and are you using both of them? What do you have for power? If you have twins do you have any porpoising problems?
Dale
Dale
I put all new fills on, I only use the one in the floor in the cockpit, I think it's 110 gal. I have 468s with Trs drives. The only time I have any porpoising is in flat water if I trim out to much.
The best I've seen is 75 on gps, I think I have 450hp a side.
