Ballast tank ?? >
Ballast tank ??
Ballast tank ??
Old 12-05-2011, 05:14 PM
Originally Posted by paul buckner
That is another way of doing it as Bullet says ,water presure fills it up very fast .there is norm an over flow fitting at the side from the top of the tank for when the tank is full , just about every ski boat here in the uk has one like this .and gravaty drain which works of a three way valve .pipe size is norm 0ne inch bore. regards paul
Paul I took a look where you advised and did a search keying ” ballast ” with no luck!!!!
I did get side tracked looking at ribs, and reading petrol...cheers....cheerio.....kilometers..... What are you guys talking about??
Mike
scarab63 is offline
Old 12-06-2011, 01:17 AM
Hi Mike go to the (Technical Question & A section ) its the first page ,14 posts down , water pickup Question. . As for wot are they talking about Q some times i dont even understand wot they are talking about ,tell me where you read it and i will see if i can translate for you LOL regards paul
paul buckner is offline
Old 12-06-2011, 04:47 AM
Wow... This just galvanizes my retardedness!!!
I was looking on page 14!!!!! For anybody else its boatmaddotcom.
Like a brit oso. Very intetesting, never been before
Thanks P
scarab63 is offline
Old 12-06-2011, 04:53 AM
c_deezy's Avatar
Wicked Won also had a fitting on the k-plane to fill the ballast tank(s).
c_deezy is offline
Old 12-06-2011, 08:06 AM
Originally Posted by scarab63
Wow... This just galvanizes my retardedness!!!I was looking on page 14!!!!! For anybody else its boatmaddotcom.
Thanks P
say no more
ROCK ON !!!!!!!!!!!!!!!!!!!!!!!!!
ITS A SKATER NATION !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 12-06-2011, 08:14 AM
Mike
Translation for ya . GAS ,THANKS .GOODBUY . DISTANCE
Old 12-06-2011, 08:57 AM
Found it so now I can fill it using just water psi while underway.
But still thinking ill need a bilge pump to pump out.
It doesnt have a bottom / gravity drain.
Thanks all.
Mike
scarab63 is offline
Old 02-06-2012, 11:52 PM
just curious if you figured out a way to go with your tank. Also any of you other guys with 500+ hp adding weight to the front of your 24, ballast or lead. JAime
JAIME is offline
Old 02-07-2012, 06:31 AM
Nothing yet. Ill most likely be going with a sm pickup coming off the tab to fill it using psi. Bilge pump to dump.
scarab63 is offline
Old 06-22-2012, 07:14 AM
c_deezy's Avatar
Just curious what the final solution was/is going to be?
Would water pressure alone force water out of a bilge pump outlet, past the bilge pump once the tank filled up? Or would you need a seperate overflow? You would need a breather hose anyhow, so I suppose the breather would double as the overflow....
c_deezy is offline
