1979 Pantera -
forabeer,
when was the boat converted to bravo ?
who decided to mount the transom assembly "(X)" where it is ? and why ?
asking because it was a tough decision for me, same measurement on my boat is 8 3/4.
have to check the notes but from memory X was 17 5/16, that should make the
propshaft height 4 1/2 inches below the bottom.
forabeer,
I did not set the x dimension. Boat was originally a TRS with big block. Previous owners had 800+ hp blower motor with the hopes of hitting the magic century mark. (hence x dimension, huge tabs, full hyd steering, etc) They ran the boat to low 90's. I am pretty sure my prop shaft is around 5" below bottom.
