Pantera factory fuel tank installation
![Unhappy](/forums/images/icons/icon9.gif)
Did Pantera install their fuel tanks with foam between the two bulkheads in the 1980s like other boat manufacturers did? I see the other boat manufactures do this and have no way for water or moisture to drain away from under the fuel tank causing corrosion of the aluminium fuel tank. Rotten front and back bulkheads and also rotted adjacent stringers. The semi closed cell foam used back in the day held water and moisture. Just wondering if Pantera boats have the same problem?
Same here, as I recall. I can only speak for my 99 vintage though
So this question triggered me the other day for a couple reasons . First do you have a Pantera that you are thinking about pulling the tank out of and you are just trying to gage how much work you are going to have to do because you don't say . Second theres nothing wrong with foam filling around the gas tank then glassing over the top to totally encapsulate the tank and as CIG3 stated there's a pVc tube glassed under the tank that alloys the front bulkhead to drain to the bilge .
But the end result is if you have the skill set to cut the floor out of the boat and get to the gas tank to remove it then I would think you have enough skill to fix a couple rotted bulkheads or stingers
The i had a guy ask me the same question about my boat the other day. Because he looked at a formula boat that fuel tank area was totally sealed off from the rest of the boat and also held in with foam. On the formula he found a bunch of rot and soggy foam.
I just finished my 88 28. There is a tube under the tank. I left the tank in when i rebuild the stringers. The side next to the tank was only bad on the top 4". the bottom section was sealed and still solid with a lair of glass between them.
