28 Real Mph Numbers
Originally posted by B-Stubb
catitude X is measured from the center of drive shaft very close to where the gimble piviots to botom of boat the v / what pitch prop 28 ?
Originally posted by Cattitude
So when you say x is 17", where are you measuring from??
After this weekend I'm going to say I may need a deeper x. I've got 20% slip, get my best at just about a 1/2 a tic above neutral on the drive, 71.6@ 4900, more trim just ups the r's without a speed gain then speed falls off about 2 notches up from neutral.
this is with about 5/8 tank and 3 of us in the boat at 1120 ft of elevation.
Mine is set at 20 1/2" because I have the nothched transom. It came from the factory with a 2" drive spacer. It was still too high and couldn't lift the bow enough. I was getting the same thing as you. Raise the trim and gain rpms and only very little speed. I put in a 3" spacer this year and it helped a bunch.
The speed will also go up when you lighten the fuel load. If I run with only 30-40 gallons and 2 people, I pick up 3-4 mph over running with 3/4+ fuel. Also if the water was flat, that hurts a lot also. A 1-2' wind chop is the best I have found for top speeds and that was even running into the wind.
PS. Sorry I didn't get a chance to give ya a call today. I have just been busier than @*&%. I'l try you tommorow night.
Performance Boat Center
Brian-
I'll be at the races.. But.. I'll be workin' our booth there. Stop by and say Hi. It'll be tough to miss our booth- Just look for the float lift hanging in the display.
Sunstream Boat Lifts.
TIM
TIM
Tim Gallagher
Performance Boat Center-FL
[email protected]
954-809-8739
Wright Performance, MTI, Cigarette, Sunsation
Tim Gallagher
[email protected]
954-809-8739
C_Spray
07-07-2008 01:47 PM
