24ft power, what do you have? >
Old 12-18-2004, 01:03 PM
  #41
Pat McPherson's Avatar
Default Re: 24ft power, what do you have?
Stormrider,
Is your engine a Gen IV or Gen V?
GM performance parts has two cams that make more power than the stock cam. And they cost less than $200 for the cam and lifters...
A friend of mine has a 94 454 Mag. We did a quick re-lap of the valves, cam change, and bolted on a new carb. He gained 300-400 rpm with the same prop.
Do a leak down test to determine where you are loosing compression. Maybe you just need to do the top end?
Patrick
Pat McPherson is offline
Old 12-30-2004, 09:56 AM
  #42
JC Performance Engines
Stormrider's Avatar
OK guys... my block has gone to the shop. GenIV, rect. ports... the good stuff.
Block is getting bored 30 over, new pistons, roller rockers, valves, cam, intake, carb.
Heads, rods, and crank are in great shape!
Gonna need an exhaust too, either Stainless Marine or Dana.
Gonna take off the drive and have it gone over... it's been at least 5-6 yrs since any work has been done to it.
Should make for an even more fun summer.
It also keeps my mind on the boat during the winter months.
Stormrider is offline
oceanoutlaw
Wanted
0
03-01-2008 12:04 PM
areyouliving
01-17-2008 08:07 PM
pq man
Baja
5
01-01-2008 01:26 PM
open87
08-29-2004 12:34 PM
Quick Reply: 24ft power, what do you have?
