How big and fast?
central ny is a great place to poker run, oneida lake has several every season most cruise at 55. We do most every run around i try to cruise at 85. Ropa has several fun runs also with many mixed boats and speeds.
If you run any of the PRA runs you must be bigger than 32 feet.
PRA (Poker Runs America) accept any boats 26' and upwards - the only reason for this is that liability insurance doesn't cover anything smaller.
Three times this year there were boats 30' and under that took away the prizes.
At Alexandria Bay in NY there is also a special cruiser class!!
Joby
Thanks for the invite! That sounds great, but I'm not too sure I want to run it in salt water. I know I can flush it afterwards, but still.... Maybe though! I'll have to see how work is in July, being in construction it's a little tough to get away for a long weekend as much as I would love to!
If you can only make one look at Jammin On The James. Go to the 07,08 Jammin threads and look at them it's a blast. You will need to get in early to get on main dock , and the past threads will tell you why the main dock is the place to be. You can go to Randy Nuzzo's site and see RPBA'S and HRPA'S pic's of past runs. We hope to see you.
www.randynuzzo.com and click ImageQuix to see past runs.
Joby
Joby
Mach1, all I can say is you do one and you'll be hooked! There is also much to be said for a PR that goes into the ocean. It's about the most fun you can have with your clothes on. I wouldn't worry about running in salt water. Just make sure you flush with fresh water at the end. And the dock party/banquet is unbelievable.
Hope you can make it down to the Ches Bay. The PRs are not so large as to attract the 120mph boats, and have plenty of "average joes" that run at speeds that don't intimidate.
Mach 1, You should think about doing the Great Sacandaga Lake(late June) and Lake George runs(columbus day w/end).
I have done Sacandaga the last 2 years(2 years ago in a 22' Scarab). A lot of people run balls out on this run, but most of the boats are single engine 28 footers. Speeds range from 55 MPH boats to 125+ MPH cats.
Lake George did not happen this past year because the organizer was too busy with other things, but the prior 2 years were a great time. They cap the speed at 60 on this run, so all the boats run together(staggerred start because there were 110 boats in '07 and the lake is only 1-2 miles wide).
The after-parties at both these runs are awesome. Plus, they are pretty cheap compared to other runs I have seen/been to.
How big and fast of a boat do you have to have to run in a say average size poker run? I've never done one and would like to do a few next season but not sure if I'll be able to keep up. What's a normal cruise speed or is it just plain balls to the wall WFO the whole time? Thanks everyone!
I'm not sure about the "big dicks" or the "blue collars" but what about the "big blue dicks collar run"?
Depends.
You have "big dick" poker runs.
And you have "blue collar" poker runs.
And then you have some that are somewhere in the middle. In the "big dick" poker runs, you will probably feel uncomfortable with your boat.
Do a little research on the run; folks here and other places can give you a recommendation. Also, talk to the organizer. A respected organizer is not going to push you into his/her event if you are not right for it.
