Cumberland Thunder Run 2013
Just a "heads up" if you have not booked your lodging at Grinder Hill Marina for the June Thunder Run you might want to call this week. I just booked today and they had (1) upper level lodge room left she did not mentioned the other room types only that they were getting "pretty full" for that weekend.
I've never been to this run before so dont hold me to this but when i phoned over the weekend to inquire about rooms and the boatels i was told they only do the Boatels a few days in advance if the houseboats are not booked to be out on the lake as rentals.
That is not the case, most likely just a uninformed winter employee, we will be having a meeting with Grider Hill to go over the 2013 Thunder Run and set boatel rates etc. soon, when that happens the info will be posted here as well as facebook and the website, you will be able to rent a boatel, if you are interested give me or Dan a call and we will give you the info. And thanks for the heads up, I will give Grider a call tomorrow and make sure they are giving correct info.
we will be there for sure , we have been to everyone dan and justin put on so far . its a good time and well organized too. Tim
If the lake levels are still down the lodge will walk you to death! Especially after a dozen beers at the party... The Boatel is the way to go for sure and it is pretty easy to get some folks to partner with you. Dan and Justin do a GREAT job and this run is a must on the schedule for the summer!!
