Powerplay 25
#31
Buizilla, it won't let me pm you give me a call at 931-265-9004 whenever you get a chance. By the way baxter is about 15 min from me. I run the boat alot on centerhill!
Frequentflyer, you are right on the driving part! From my understanding the open deck model is a bit heavier, correct me if I am wrong.
Thanks Mike
Thanks Mike
Don't know how your weight distribution is so Cleavers might work...
#32
That's what I have heard too Mike but I have never actually been on a closed cockpit. On my boat you needed choppers though and not cleavers. I ran my boat with Hydromotive 4 blades once and almost cut my veins. My boat needed lift... Dave and Bill had done all the research and tried every combination but I decided to be a bad a$$ and try something different. Suffice to say, I went right back to the chopper 26s. Never did try Cleavers though...
Frequentflyer which way are you running your props? Mine are spinning out, but going to try spinning them in this year.
#33
I like Bravo I's on mine. I going to try a pair of labbed 28's this spring. The ones I run now are stock 26's. Also going to try a friends Hydromotives and see how it runs.
My boat would just not run right unless I was running chopper 2s for some reason. I sold it and bought a fishing boat (Bull Dolphin 22') with a laser but when I tried a chopper on it the boat was dramatically different too. The chopper picks the boat up out of the water and gives you a light steering feel. It's strange to describe unless you have experienced a boat with and w/o a chopper. If you can get your hands on some test chopper 2s, try them. Just let me know... I ran my props spinning outward.
#35
