Part For K-plane
Brotherhood #1
I dont believe thats a plug but a valve.Check the mer website.Whats wrong with yours? if it just a leak should just be an oring behind there found at most parts stores for a/c units and such.
-Mike
-Mike
Mike
Mine seems to have been dameged maybe because it has been with the wrong tool , the top of the plug is not 6 side anymore ( hex) and one of the side is so detroyed and so short than it cut the o-ring.
I have found some explosed view of the pump on crowleymarne but no ref off the plug
What do you means by mer website ?
Brotherhood #1
Mercury marine. See if you can pull a diagram of it then email them that should do the trick if not let me know ill do some hunting my self. BTW how did it get f'd up that bad
-Mie
-Mie
Brotherhood #1
http://www.oemsurplus911.com/hyd_m-s/oildyne.htm
check it out also this is the p/n id ask about
-OILDYNE
OF2-SHKW-50H-1-15
FLOW CONTROL VALVE
-OILDYNE
OF2-SHKW-50H-1-15
FLOW CONTROL VALVE
Brotherhood #1
http://www.plccenter.com/sm/Oildyne.html
this siote has valves and pressure switches just find the right one and your set
