502 rebuild advise
502 rebuild advise
Ok need some help from the experts here thank you in advance . I am wanted to rebuild my 502 mpi I would like to build a 540 if that's the best way to go . If so need advise crank kit cam & heads I really would like to keep the efi if possible I have built a few street cars and i know the marine engine is a different animal so thats why I am here .Also I am running emi wet exhaust .Would like to achieve around 700 hp if possible Thanks again for any help
You should move this post over to the technical section there's more people over there. With the cam & heads advise you should call RM Builder it's one call you wont regret making.
have a pair of 598 ci engines that would be nice in that ... carbs... motors just gone thru with open checkbook .. 7-800 hp depending on cams .. reasonable ,pm if interested
motors sit pretty close now would I have room for a pair of tall decks and want to everything under the hood.
Yes I do 585-654-8583 Bob
