Stress Cracks Common for PQ
![Post](/forums/images/icons/icon1.gif)
I had a 1997 260 PQ that had 175 hrs when I sold it last fall and it didn't have a single stress crack. My boat had snaps for the tops, bow rails, stern rails and windshield. I have seen other boats that had cracks from these items not having the holes drilled properely.
OSO Moderator
I had a '00 280.
NO stress cracks anywhere!
Boat was VERY solid.
BillR
'00 Scarab Sport 302 CC
'02 Cigarette Top Gun TS
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
I have a 98 260. I have some minor stress cracks by the windshield on the port side. I've owned a Checkmate a Donzi and other boats, and they all had some stress cracks.I've also seen them on other boats that my friends own. I just think that it is normal for a boat that is subjected to the abuse we all give them. It is just the gelcoat and not a structural thing.That's just my .02
![Smilie](/forums/images/smilies/smile.gif)
Charter Member #30
I have had quite a few especially near a radius like the ones Ray has. They have repaired and strengthened all but two that were created by taking one on the side it was a hard hit and they are located on the cockpit floor area. I was hoping they would fix them but PQ decided it wasn't a warranty issue. Whether I agree or not with that decision I can certainly understand that they can not be fixing every single crack in there boats. I do know that when they find a problem area they change there production to reinforce that area.
There are a couple questions that I have wondered about. Is the gel too thick? Are the stress areas put together too tight? With any material or structure some type of expansion joint or buffer needs to be used to absorb shock. SCOTT
I have Steps & Bubbles!
Member "69" Charter #70
I would like to email some of you guys a zip file of pics I took of my cracks and also sent to PQ. Maybe some of you who have had stress cracks can compare, and post feedback.
Maybe I am over reacting.
I do know after I sent PQ the pictures they asked how many areas I had so they could get an idea of hours of work involved, but when I emailed the following list, they informed me it was not covered.
My cracks
14 cracks around the windshield. All cracks start on the cockpit side of
windshield and extend into bow. All cracks are 3" or longer( one is 9"). None are
spider web type cracks you normally see in gel, all are deep and you can
feel when you run your hand over them.
4 cracks in the stripe that is gel coated into the bow, one deep like around
the windshield.
3 cracks around the pump out fitting, all similar to the ones around
windshield.
Jan
[ 01-24-2002: Message edited by: Jan ]
My cracks
the windshield.
windshield.
Jan
Charter Member #30
Jan, non of mine were even close to what your describing.
New to Power, The repairs looked good a little shade difference do to sun fade but 90% of my trouble was in the cockpit area so it wasn't a issue.
If you call PQ I'm sure they would give you the gel manafacturer and part #. I have learned a little bit about this type of repair it seems most of them require some type of reinforcement from the underside or pressure relief.
I had to re-glue my head liner after the first year, what a job! The problem seemed to be the wiring harness that ran the length of the cabin on the stbd side was not secure and started to sag on the carpet. If I keep the boat might look at the cost of installing a suspended head liner
