Cabin Door
#31
Re: Cabin Door
Originally Posted by Scott
Although the loose screws (should re-tap and use loc-tite) should not happen. He or any performance boater should not run with a sliding cabin door closed. This puts way too much stress on the door and lock area (prone to cracking)
You mentioned that performance boat doors should always be left in the open position to reduce the amount of stress. How about if the door swings open, not on slider? Would you still recommend keeping it open while cruising then or should it be closed? I had always been told to keep it closed to eliminate stress and possibly swing close and damage.
We will re-tap and loctite his screws soon as weather permits. Thanks again!
#32
Re: Cabin Door
I agree with Mactimes earlier post concerning performance figures on the 300 Revenge. I have owned mine for two years now. We always run with the door in the open and latched position (or totally closed). I have never had it come off track yet. Looking into where the door is stored, I am concerned about stuff, junk, dirt etc getting into the track and being almost impossible to clean out. Thanks to this discussion, I will investigate a latch for the top of the door and will be looking at the screws real close.
As for the rest of Mactime's friends Revenge problems, I agree with Mig, probably the environment. We boat on a Corp lake and it is positioned predominately north and south, so it is rough a lot but not normally more that a foot or two. However, I have ALWAYS made sure the door was open and latched or closed and secured. It never is left to slide by itself.
On another note, we are having some scratches fixed today.....boy is this going to be an expensive day!!! Ouch.
#33
Re: Cabin Door
#34
Charter Member #30
Re: Cabin Door
Originally Posted by MACTIME
Thanks. I will relay this to him and hopefully this will resolve his problem.
I have Steps & Bubbles!
#35
Re: Cabin Door
Mactime, We have run 78 and some change when prop testing. I have the props away getting worked on right now and the first report was one was slightly deformed(?). Never heard of that. It is interesting to note that one engine always turned about 100-150 more RPM. I cannot wait to test again.
Here is a picture of our boat:
#36
Re: Cabin Door
Originally Posted by MK
#37
Charter Member #30
TTT
I have finally started this project. Last year I had to quit boating projects do to a move that ended up happening in July (man did that suck)
Anyway I cut the hole giving me full access to the area behind the helm. I'm thinking of just using 4200 to fasten the rear track and hold the front in with longer screws through the back of the channel. This way I can still replace or repair the door glides if they fail.
I did have a long talk with Dennis (the guy from the company that made it) He pulled out the drawings and I could tell he was not at all happy with the two piece track design not to mention their fastening system. Very helpful and ready to send parts if needed.
If anyone has some input or experience with this Speak up!
#39
the door that came with my 96 was junk. factory said they changed doors. I switched mine to the new version door they were using before they shutdown and it has held up much better then the pos that came with it.
#40
Charter Member #30
