Battery Charger help
Re: Battery Charger help
Mine were totally discharged, nothing there, dead. When I started the charge the gague in the charger read at 15 amps. The gague max is 30 amp. After a couple of hours the gague jumped to max on the gague and then gradually came down to the 20 - 25 range. I just put it on again tonight for an hour and when I shut it off it was
at 18 - 20 amps.
Will check the batterys with a hand held volt meter tomarrow after they settle and see what I have.
at 18 - 20 amps.
Charter Member #30
at 18 - 20 amps.
at 18 - 20 amps.
Load tester
They are also available at sears and many other places I just clicked on the cheapest
I have Steps & Bubbles!
tpmarine.com
New Products and Member Discounts
4
02-02-2006 09:50 AM
