Power hatch relay
#32
If it just happened without notice, its likely a fuse or connection.
If you messed with your batteries at all I would check and verify all connections at the Batt and Relay are good.
#33
Ok, I will check that.. I think with how well and how normal it had been working that it is probably not stripped. I think it has to be electrical. If it still works going down but wont work going up, that wouldn't be a fuse would it??
#35
I had the power lead to my relay disconnected the other day and the hatch would go down. Not sure why really but it did.
I was in the middle of chasing down a voltage problem when I found it. My gripe with my boat is wiring... IMO it was not wired to take lake michigan abuse. Dash is daisy chained together and found the connection off the blower switch was poor/starting to fail..thus everything after the blower was not getting appropriate voltage. I will be permanently fixing that prob over winter.
#36
#37
Registered User
I installed the relays for the power hatch last night and everything went great. looking at the drawing in an earlier post can somebody tell me what size fuse to use in the 12v + wire ? I am guessing 20 amp.
#39
I am having problems wiring this up. At the dash I have a dpdt switch wired with the power and grounds crossing making an x, and the output wires for up and down in the middle. These are going straight to my hatch rams. When I put in the relay wired like the diagram states I get nothing. Can someone help me. Here is the image of my current set up. Thank you in advance.
![](http://www.eddiemarine.com/techsupport/assets/302_act_instructions1.jpg)
#40
Were doomed!
what relay diagram are you trying to use? the one i posted a picture of??? if that the case then the problem is the power supply you have going to the switch....dissconnect that battery feed from your dash switch.
If you have the relays wired up for a positive trigger then dissconnect the negative feed so only battery power is supplied to the relays....
-Wally
-Wally
