Go Back  Offshoreonly.com > Owners Forum > Powerquest
34 vyper 336 formula >
Old 03-27-2007, 09:05 PM
I dont count on any factory support when I buy used!
its hard enough to get any when the boat is under warranty .
Silverado
I thought you work for PQ at one time.Why are you knocking them?
boatnt is offline
Old 03-27-2007, 10:28 PM
I'm not knocking them or bad mouthing them. I hope they make a comeback, but if I was boat shopping, I would want to be able to call someone who knows the product in and out, regardless if the problem was warranty or not.(wiring harnesses, what kind of vinyl/paint/gelcoat and colors were used for certain model years, "X" dimensions,etc.) That's all I was getting at, not smashing PQ or the product.
Silverado is offline
Old 03-28-2007, 05:30 PM
I just bought a used 290 and called the factory today with some questions and spoke with Bob.
10 minutes later he called me back with all the info I needed.paint codes etc.I think that a good start.
Now on to other things.since you worked at the factory what can you tell me about the 290 and the chine walk issue that most have.
boatnt is offline
Old 03-29-2007, 07:09 AM
Enticer Rick's Avatar
Location: Lake St Clair Metropark, Harrison Township, MI
boatnt,
Did you get alot of water in your bilge in your previous 29? Im not really sure were it is coming in at. I'm thinking the vents when it rains.
Enticer Rick is offline
Old 03-29-2007, 07:51 AM
I'm guessing the tabs you have are 12X13 Insta Trim. Look at them when they all the way up. IF they are negative, it would help to leave them down so they are parallel with the hull bottom. This should help stabilize the boat with out scrubbing speed. Larger/Longer tabs would also help, but could be a pricey option.
The other thing to check is the "toe" on your outdrives. Sometimes this can cause some handling issues as well. Measure the distance between your prop shafts on the back of your drives and the on skinny part of the case just above the bullet in the front. It should be close to 35 1/4" both front and back. If not, you'll have to loosen the inner and outer tie bars to make the adjustments.
Other than that, not much else to suggest other than full hydraulic steering, but I know that is very expensive.
Did you ask "BOB" at the factory about the chine walk and if you did, what did he have to say. I'm just curious because I don't know who Bob is or who they have working there currently.
Old 03-29-2007, 08:23 AM
Macklin's Avatar
Originally Posted by 32velocity
thanks for all the input,,I was originally looking for a 336 you know the Formula name and reputation......but I went last year w/o any luck finding a clean one that wasn't "rode hard and put away wet" so to speak,, and this year is looking the same way so I decided to expand my choices ......
I just lowered the price on my 340 in the classifieds. This boat is in showroom condition - gauranteed!
New boat on the way so it's gotta go.
PM me if you would like additional info.
Macklin is offline
Old 03-29-2007, 11:12 AM
PWRQWST's Avatar
Macklin, what did you decide on?
Rich.
PWRQWST is offline
Old 03-29-2007, 12:30 PM
OSO Moderator
BillR's Avatar
Macklin is jumping ship.
He ordered a brand spanking new Active Thunder.
Now we're gonna call him Mactive.
BillR
'00 Scarab Sport 302 CC
'02 Cigarette Top Gun TS
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR is offline
Old 03-29-2007, 06:23 PM
Mentalpause's Avatar
Rich.
Rich - go here. Pretty much shows Macklin's new ride. Very nice.
http://www.offshoreonly.com/forums/s...d.php?t=153275
Mentalpause is offline
Old 03-29-2007, 06:35 PM
Macklin's Avatar
Long thread. You have to go all the way to page 5, I think, to see the final rendering.
It is being clear coated now!
340 for a steal!
Macklin is offline
Quick Reply: 34 vyper 336 formula
