Go Back  Offshoreonly.com > Owners Forum > Powerquest
Has anyone every had any bottom work done on a 260? >
Old 12-24-2007, 10:13 PM
  #31
Originally Posted by Fast Forward
So whats the cerdict on the hull?? Does she have a hook??
I guess you didn't see my earlier post. It will probably be Spring before I do I anything. That is unless someone buys the motor from my Pachanga or the Pachanga. I'm gonna bump my thread in the swap section after the 1st of the year. If I don't don't get any responses I'm gonna have my boat guy finish the Pachanga project! Hydraulic Steering,Tabs,Exhaust! I figure if I blow buy somma these guys in a pristine 87 Pachanga doin 90 give or take someone will want it! After that I will do more research! I have been following the Hull Hydromatics? thread very closely! We will see!
pachanga is offline
Old 12-25-2007, 10:44 AM
  #32
Mentalpause's Avatar
Probably take some decent power to push that hull to 90. Just like the sibling Envision...they are awesome rough water boats but the hull is not very efficient.
Mentalpause is offline
Old 12-25-2007, 09:55 PM
  #33
I had a 454 Built from top to bottom for the procharger setup. It has a conservative 600HP. Probably more if I decide to let the RPM's loose. I hope I can keep the RPM's under 5500 and do what I want it to do. The setup is supposed to be good to 6000 or a bit more but I figure that will shorten the life a bit!
pachanga is offline
Unitek
Fiberglass and Paint
8
08-24-2007 07:00 AM
Prater
29
01-11-2005 04:23 PM
Quest for Speed
Powerquest
16
01-06-2005 11:18 AM
Ran-Dom 32
06-10-2003 10:46 AM
Kokopelli
13
01-26-2003 10:30 PM
Quick Reply: Has anyone every had any bottom work done on a 260?
