Prop Testing
OSO Moderator
There is a anti siphon valve on / near the tank that could be bad.
Have your tech hook up scan tool to monitor fuel pressure while running. I still think it could be a tach problem - which feeds back to distributor and the distributor tells the ECM to reduce or shut off fuel.
BTW: PM me your address - I have some goodies for ya.
BillR
'00 Scarab Sport 302 CC
'02 Cigarette Top Gun TS
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
I've also had a soft spot in a fuel line once which causes it to collapse at higher RPMs, choking it for fuel, yet it will idle all day long without a problem, or run at pretty low RPMs. The choking was also sporadic when it happened. Nice thing was the fix was cheap and easy.
There is no anti siphon valve. I must've been removed. Weird but the pick up tube is welded inside the tank.......it can't be removed. I'm checking the tach and other electronics tomorrow.
OSO Moderator
Now get that puppy up over 65mph!
BillR
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
