PQ General Discussion
#2137
I have not been spending too much time on here lately,trying to kick the habit...
but I thought I answered your questions back on reply 2055!
Today you text me a question about the oil weight and I text you right back.. please let me know if theres anything else I could answer for you or what question I missed.
Originally Posted by cpiefer06
Boatnt if you could way in on this would be great but anyone else is more than welcome to as well.
First time out with new boat and we loved it and all went well, but I do have two questions.
1. The left shifter seemed a bit reluctant at times to go into gear, is there an adjust for that? And then I would bet it would be back back at the motor right? Lastly did you ever encounter similar? Just curious.
I never had any problems with either engine on the 300 going in gear,on one of my 290s I had one engine was at times a little hard/stiff to go in gear,I had to (simple repair)remove the top/side cap on the outdrive and clean and lude the detend spring/check ball assembly,that took care of it and I was told Merc recoments you do that every couple of years.------------------------------------------------------------------------
2. The throttles seem like they could use a bit more resistance or tension on them as one or both seemed to move a little while under way. Like once we were going and were at desired pace I would let go and look back a bit later and they were no longer side by side.
I never drive with my hands off the throttle so I would never known but it is a simple adjustment,,with the engines OFF!!!move the throttles forward spread the black rubber boots apart and you will see a allen head screw,you can turn it in 1/2 a turn at a time until you get the resistance you like,same could be done with the shifters as well,,Hope this helps and hope you enjoy your new boat,
Tom
