Big Power
bringing thread back to the top! ive been doing some thinking and will see what I wanna do after I see results with my fresh motors but my 97 hull might be fun to throw some bigger power at, in the near future! keep my factory 502's for resale and find some other motors and start building to drop in it down the road! was thinking some ls type power! 6.0's with turbos. roughly 700 hp a side should be plenty of torque to get on plane and have some fun with the rpms! yes it might be a waste of time but sure would be cool to have a 90 mph 380 running around!
that's sweet I would love to hear how all that turns out! I love these 380's just wish they build bigger then 380, but beggars cant be choosers so ill take what I have AND have some fun with it!
gimmie what do u have in you 380 right now?
Twin 502 MPI. Going through and doing some thorough maintenance right now because it sat a couple years before I bought it. Then I will be trying some props as ones that came on it are mis-matched. One appears to be labbed and other appears stock. Engine revs reflect this. Starboard engine will bounce on limiters while port is at 4900. I also have a bad trim indicator on starboard and that drive trims faster than port so there is some issue too. I ran it yesterday and trimmed to match rpm. I have a set of 29p Hydromotive and a set of 31p Mach sterndrivers to try for s*** & giggles. Running 28p Bravos now. Factory performance report said it radared at 71.8 with 28p Bravos. It appears I have an early 2000 hull with a bit of hook in the stern yet. I will probably end up shaving some additional lifting strake off like Wildman1 did with his 99.
Well, the boat hated the 31p Mach's. Boat would almost get on plane and just blow them out. Didn't matter tab position or if gentle or hard throttles. They were awesome looking props and I thought they would have worked well. Lots of rake, good sized blades, some good cupping, lab finish, and full 15.5" diameter......nope!
29p hydromotive should show up this week. See how those work although after the mach failure, not sure since similarly shaped props. We will see. I have a set of lab 30p bravos offered to try as well along with some 32p bravos.
mine ran 26 bravo1 4 blades. The factory swore it was the best prop and the hull was designed around it. They have the best bow lift which is what these hulls need. Hydros are more of a stern lifting prop, probably wont work but give it a shot. There have been a number of new props come out since then, I would do some research and see if any are designed for bow lift. Did you place a 4 straight edge on last 4' of running surface? It will tell you how much of a hook you have left.
I loved running mine directly into the waves head on or trailing seas. Ride was awesome. In confused seas which Lake erie is most of the time or quartering them and having to hold a heading to get somewhere is when i wanted to sink or light it on fire some days. Lol. Sounds like you are close, just dont spend too much on power and props till you get the bottom work done first. They are great boats, enjoy
I have a 99 380 Avenger. In the winter of 99 my son and I put Stainless Marine headers on the 502 mpi's this took the boat from 68 mph stock to 72 mph withthe headers also change the air intake. Winter of 2000 put stage 1 pro charger on the mpi's. Boat radar gun at 88 mph but took off to the right with 3/4 throttle left. That summer I kept blowing the top bearing out of it so in the winter of 01 I bought two 500 EFI's and said the hell with it. The boat now run 82 mph on the gps with 1/4 tank of fuel and two people. Above 80 she will start to chime walk trim out. The boat runs flat. The factory redid the bottom and blueprint the bottom. If I were you stay away from the pro chargers or you will get good at changing drives.I am now running 30 pitch lab merc props @ 5200 rpm's
